- This topic has 1개 답변, 2명 참여, and was last updated 16 years, 7 months 전에 by
ELem. This post has been viewed 1557 times
제 듀얼모니터 xorg.conf 설정 정보입니다. 참고하세요. ^^
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings: version 1.0 (인베인 ) Thu Jun 5 09:26:53 UTC 2008# xorg.conf (X.Org X Window System server configuration file)
# This file was generated by dexconf, the Debian X Configuration tool, using
# values from the debconf database.
# Edit this file with caution, and see the xorg.conf manual page.
# (Type "man xorg.conf" at the shell prompt.)
# This file is automatically updated on xserver-xorg package upgrades *only*
# if it has not been modified since the last upgrade of the xserver-xorg
# package.
# If you have edited this file but would like it to be automatically updated
# again, run the following command:
# sudo dpkg-reconfigure -phigh xserver-xorgSection "ServerLayout"
Identifier "Default Layout"
Screen 0 "Screen0" 0 0
EndSectionSection "Module"
Load "glx"
EndSectionSection "ServerFlags"
Option "Xinerama" "0"
EndSectionSection "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "XkbRules" "xorg"
Option "XkbModel" "pc105"
Option "XkbLayout" "us"
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
EndSectionSection "Monitor"
Identifier "Configured Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "CRT-0"
HorizSync 30.0 - 81.0
VertRefresh 56.0 - 75.0
EndSectionSection "Device"
Identifier "Configured Video Device"
Driver "nvidia"
Option "NoLogo" "True"
Identifier "Videocard0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BoardName "GeForce "
Option "Rotate" "CCW"
EndSectionSection "Screen"
Identifier "Default Screen"
Device "Configured Video Device"
Monitor "Configured Monitor"
DefaultDepth 24
Identifier "Screen0"
Device "Videocard0"
Monitor "Monitor0"
DefaultDepth 24
Option "TwinView" "1"
Option "TwinViewXineramaInfoOrder" "CRT-0"
Option "metamodes" "CRT: 1280x1024 +0+1024, DFP: 1280x1024 +0+0"
EndSection* 오픈소스는 Open Innovationa & 윈윈전략을 도모할 지언정 절대 공짜(무료)임을 뜻하지 않는다.치
