[tip - tech] vmware player 페도라 설치시 진행이 안될 때
게시판 Tech/Tip [tip - tech] vmware player 페도라 설치시 진행이 안될 때
  • This topic has 1개 답변, 2명 참여, and was last updated 5 years, 1 month 전에 by
    태랑. This post has been viewed 1092 times
  • #103324
    1.페도라 34에서 내려 받은 VMware-Player 설치가 일반적인 설치가 되지 않을 때
    unistall
     2. 선택 부분을 추가해주어 진행한다.
    • 설치를 위해 아래 설정 값을 추가한다.
            --console --eulas-agreed --ignore-errors
    3. 정상 설치 동작
    [root@nalkal Downloads]# ./VMware-Player-16.1.2-17966106.x86_64.bundle --console --eulas-agreed --ignore-errors
    Extracting VMware Installer...done.
    VMware's Customer Experience Improvement Program ("CEIP") provides
    VMware with information that enables VMware to improve its products
    and services, to fix problems, and to advise you on how best to deploy
    and use our products. As part of the CEIP, VMware collects technical
    information about your organization's use of VMware products and
    services on a regular basis in association with your organization's
    VMware license key(s). This information does not personally identify
    any individual. Additional information regarding the data collected
    through CEIP and the purposes for which it is used by VMware is set
    forth in the Trust & Assurance Center at
    http://www.vmware.com/trustvmware/ceip.html.  Join the VMware Customer
    Experience Improvement Program ("CEIP")? If you prefer not to
    participate in VMware's CEIP for this product, you should select "No"
    below. You may join or leave VMware's CEIP for this product at any
    time. [yes]: yes
    Enter license key. (optional) You can enter this information later.:
    The product is ready to be installed.  Press Enter to begin
    installation or Ctrl-C to cancel.
    Installing VMware Player 16.1.2
       Configuring...
    [######################################################################] 100%
    Installation was successful.
    4. 일반 설정과 브이웸웨어 상태에 따라 제한이 있는 경우에 위와 같이 설치를 진행 할 수 있습니다.
    • #103325
      좋은 팁 감사합니다~!!
드디어 다음주면...
그동안 즐거웠습니다........
가입인사...^^
[Fedora14] X-window logout하면 서비스가 종료됨
모두 풍성한 한가위 추석 연휴 되세요~!
페도라 하이브리드 - 윈도우 Mdir
레벨 3 인증
가입인사드립니다
설날이내요 ~
cockpit을 이용한 리눅스(페도라) 시스템 가상화
