페도라에서 snap을 통한 cider 실행
홈 › 게시판 › 질문게시판 › 페도라에서 snap을 통한 cider 실행
  • This topic has 2개 답변, 3명 참여, and was last updated 4 years, 5 months 전에 by
    태랑. This post has been viewed 894 times
  • #110735
    acatundercar
      게시글2 댓글0 총합2
    @acatundercar
    리눅스를 쓰기전에 애플 제품을 주로 써서 애플뮤직 구독자인데요.
    리눅스에서 애플뮤직을 쓰니 디자인도 조악한 편이고 브라우저 안에서만 실행해야하는 불편함이 있어서
    다른 앱을 찾다가 snap에서 cider라는 프로그램을 찾았어요.
    문제는 소리가 안나요. 다른 프로그램도 몇개 써봤는데 snap을 통해서 실행하면 전부 다 소리가 안나요.
    터미널 기록 올려드립니다. 고수분들 도와주세요 ㅠㅠ
    [root@fedora acatundercar]# snap run cider
    2022/05/17 12:55:41.832950 cmd_run.go:1053: WARNING: cannot start document portal: write unix @: sendmsg: broken pipe
    [12:55:49.076] [info] [AppEvents] App started
    Failed to open connection to "session" message bus: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
    [12:55:49.630] [info] [PluginHandler] Loaded plugins: [
    'chromecast.js',
    'discordrpc.js',
    'lastfm.js',
    'menubar.js',
    'mpris.js',
    'raop.js',
    'thumbar.js',
    'webNowPlaying.js',
    'iVancedPlugin'
    Gtk-Message: 12:55:50.175: Failed to load module "pk-gtk-module"
    Gtk-Message: 12:55:50.204: Failed to load module "pk-gtk-module"
    [4125:0517/125550.461639:ERROR:bus.cc(397)] Failed to connect to the bus: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
    [4125:0517/125550.461781:ERROR:bus.cc(397)] Failed to connect to the bus: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
    [12:55:50.909] [info] [AppEvents] App ready
    [12:55:50.910] [info] [Cider] Application is Ready. Creating Window.
    [12:55:51.146] [info] [Connect] Auth URL: https://connect.cidercollective.dev/callback/discord?app=cider&appPort=9000
    [4125:0517/125551.331324:ERROR:bus.cc(397)] Failed to connect to the bus: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
    [12:55:51.347] [info] WebSocketServer started on port: 26369
    [12:55:51.463] [info] [Cider][Widevine] Status: {
    oimompecagnajdejgnnjijobebaeigek: {
    name: 'Widevine Content Decryption Module',
    status: 'new',
    version: '4.10.2449.0'
    [12:55:51.464] [info] {
    auxAttributes: {
    amdSwitchable: false,
    canSupportThreadedTextureMailbox: false,
    glResetNotificationStrategy: 0,
    inProcessGpu: true,
    initializationTime: 0,
    isAsan: false,
    jpegDecodeAcceleratorSupported: false,
    optimus: false,
    passthroughCmdDecoder: false,
    sandboxed: false,
    softwareRendering: false,
    subpixelFontRendering: true,
    videoDecodeAcceleratorFlags: 0,
    visibilityCallbackCallCount: 0
    gpuDevice: [
    active: false,
    cudaComputeCapabilityMajor: 0,
    deviceId: 0,
    vendorId: 0
    [12:55:51.472] [info] From here can you check for real changes, the initial scan has been completed.
    [12:55:51.472] [info] Cider client port: 9000
    [12:55:51.489] [info] Cider remote port: 6942
    [12:55:51.515] [info] remote broadcasted
    WARNING: Kernel has no file descriptor comparison support: Operation not permitted
    [4301:0517/125552.200886:ERROR:sandbox_linux.cc(377)] InitializeSandbox() called with multiple threads in process gpu-process.
    [4125:0517/125557.191759:ERROR:bus.cc(397)] Failed to connect to the bus: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
    (cider:4125): libappindicator-WARNING **: 12:55:57.423: Unable to get the session bus: Error sending credentials: Error sending message: Broken pipe
    (cider:4125): LIBDBUSMENU-GLIB-WARNING **: 12:55:57.425: Unable to get session bus: Error sending credentials: Error sending message: Broken pipe
    [4301:0517/125557.799407:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 1 times!
    [4301:0517/125557.813155:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 2 times!
    [12:55:59.910] [warn] This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    [12:55:59.912] [error] Error: An object could not be cloned.
    at EventEmitter.t.ipcRendererInternal.send (node:electron/js2c/sandbox_bundle:49:353)
    at EventEmitter.<anonymous> (node:electron/js2c/sandbox_bundle:45:357)
    [12:55:59.913] [error] (node:4125) UnhandledPromiseRejectionWarning: Error: An object could not be cloned.
    (Use `cider --trace-warnings ...` to show where the warning was created)
    [12:55:59.914] [error] (node:4125) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 4)
    [12:55:59.980] [info] /root/snap/cider/47/.config/Cider/Plugins/gh_475359369
    [12:55:59.994] [info] /root/snap/cider/47/.config/Cider/Plugins/gh_475359369
    [12:56:00.067] [info] /root/snap/cider/47/.config/Cider/Plugins/gh_475359369
    [12:56:00.080] [info] /root/snap/cider/47/.config/Cider/Plugins/gh_475359369
    [12:56:00.158] [info] /root/snap/cider/47/.config/Cider/Plugins/gh_475359369
    [12:56:00.190] [info] /root/snap/cider/47/.config/Cider/Plugins/gh_475359369
    [12:56:00.205] [info] /root/snap/cider/47/.config/Cider/Plugins/gh_475359369
    ALSA lib conf.c:3916:(snd_config_update_r) Cannot access file /usr/share/alsa/alsa.conf
    ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM default
    [4403:0517/125621.371473:ERROR:alsa_util.cc(204)] PcmOpen: default,No such file or directory
    ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM plug:default
    [4403:0517/125621.371791:ERROR:alsa_util.cc(204)] PcmOpen: plug:default,No such file or directory
    [4125:0517/125624.518704:ERROR:bus.cc(397)] Failed to connect to the bus: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
    [4125:0517/125624.518802:ERROR:bus.cc(397)] Failed to connect to the bus: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
    [12:56:35.777] [info] Example plugin stopped
    [12:56:35.778] [warn] Cider exited.
    • #110736
      cider는 애플뮤직 클라이언트입니다. 맥도 크게 보면 리눅스 시스템이긴 하지만,
      동작 특성에 적합한 부분인지에 대한 부분과 실제 음악관련 프로그램도 잘 동작하는 부분등으로
      시스템 사용자 특성에 알맞게 잘 사용하고 있습니다.
      해당 동작을 진행하기 위해서 점검 부분으로, 실제 사용하고 있는 장비 상태, 사향, 페도라 버전등의 대한
      정보가 필요합니다.
      해당 cider 지원 부분은 F35에 권장된 시스템 형태를 갖으며, 필요한 라이브러리와 snapd가 동작 중인
      상태에서 진행해야 하고, 관련 프로그램 libindicator, libbusmenu와 연관된 프로그램, 동작 중에 나타나는
      부분을 추가하여 설치하여야 합니다.
      cider run
      The Zane Lowe Interviews에서 소리 특성을 확인하고, 영상동작까지 잘 동작합니다.
      system run for Cider
      결론적으로, 실제 진행 동작은 잘 동작하는데, snapd로 진행하는 것이 아닌 컴파일 설치를 통해 진행해서
      동작 시켰습니다. 잘 동작합니다.
      해당 동작은 F36 Server/KDE를 올린 상태에서, Cider Docs에 제공한 정보를 사용하여 동작한 부분으로
      해당  웹을 통해 참고해서 설치와 동작을 진행하면 됩니다.
      https://docs.cider.sh/compilation/compiling-on-linux
      해당 부분은 동작을 확인 후에 답변 부분을 수정하였습니다.
      화이팅!
      • #110752
        컴파일로 하셨군요
        테스트까지 ~ 감사합니다.
trans-ko... 존재했던거군요...
드디어 시험이 끝이 났내요 ..
흐윽.. 압축이 풀어지지 않아요.
페도라 20설치를 하려는데요.
페도라 16을 멀티부팅으로 설치하려고 하면 이런 메시지가 뜹니다.
perl을 이용한 웹 프로그래밍에 관해서
페도라 33 그놈 데스크탑 테마 적용
7분동안 프로그래밍 언어 맞추기
바쁜 생활중인 태랑입니다~~
Cent OS - US ver-
