VTune Performance Analyzer 8.0.1($59.95)
홈 › 게시판 › Tech/Tip › VTune Performance Analyzer 8.0.1($59.95)
  • This topic has 0개 답변, 1명 참여, and was last updated 16 years, 9 months 전에 by 인베인. This post has been viewed 1235 times
  • #12115
    https://premier.intel.com/
    https://registrationcenter.intel.com/support/
    http://www.intel.com/software/products/
    http://www.intel.com/intelpress
    1. Download & Installation
    fc5#> tar zxvf vtune_linux_8.0.tar.gz
    fc5#> ./install.sh
        The format of the serial number is: XXXX-XXXXXXXX
    fc5#> ls /opt/intel/vtune (installation directory.)
    fc5#> cat /var/log/vtune_install.log
    fc5#> vi /etc/profile
    export PATH=$PATH:/bin
    fc5#> ./vtl version
    VTune(TM) Performance Analyzer 8.0.4 for Linux*
    Copyright (C) 2000-2006 Intel Corporation. All rights reserved.
    Installed Intel(R) Software Development Products:
    Build: 750
    fc5#> tree
     +-- opt
          + -- sag (EntireX package directory).
          + -- intel
                +-- eclipsepackage (Eclipse* package)
                +--  vtune ( for the VTune analyzer files).
                     +-- bin (binaries and executable files).
                     +-- doc (documentation files).
                     +-- man (man pages and files associated with this product).
                     +-- rdc (VTune analyzer Remote Agent).
                     +-- samples (VTune analyzer getting started sample files).
                     +-- vdk (VTune analyzer driver kit).
    2. Start
    fc5#> cd /opt/intel/vtune/samples/gsexample
    fc5#> make
    fc5#> ./gsexample2a datafile.txt
    fc5#> /opt/intel/vtune/bin/vtlec
    "+"Click - First Use Wizard - Application to profile -
    .Application to launch: /opt/intel/vtune/samples/gsexample/gsexample2a
    .Application arguments: datafile.txt
    .Working directory    : /opt/intel/vtune/samples/gsexample
    3. uninstall
    3.1 how to unistall normally
    fc5#> /bin/uninstall_vtune.sh  (VTune analyzer for Linux)
    fc5#> /bin/uninstall_vdk.sh   (VTune analyzer Driver Kit)
    fc5#> /bin/EPuninstall.sh (Eclipse package)
    fc5#> /bin/uninstall_rdc.sh  (Remote Agent)
    3.2 How to uninstall manually
    fc5#> rpm -e --nodeps --noscripts `rpm -qa | egrep 'intel-vdk|intel-vtune'`
    fc5#> rpm -e --noscripts `rpm -qa | grep dcom`
    fc5#> rm -rf /opt/sag
    fc5#> rm -rf /etc/dcom
    fc5#> rm -rf /var/log/dcom
    end of line.
인베인님, LiveUSB는 테스트해 보셨는지요?
FOSDEM 2021 - 영상 배포 소식
랩탑에 F40 올려 보았습니다.
페도라 13은 yum 리포지토리 추가 안해도 되나여?
위지윅 Fckeditor 설치 방법
[안내]gnome-shell-3.26.2의 stat tracker log 반복 현상에 대한 patch 안내
페도라 12에서 달라진점 발견한거 있나요 ?
완벽한 데스크탑 활용 - 페도라 열두 버전
그동안 즐거웠습니다........
오늘 하루는?
